Hello Guest it is October 20, 2026, 08:34:15 PM
Author Topic: Mach3turn Stop button?  (Read 9674 times)
« on: December 07, 2020, 09:45:01 AM »
Hi all,
I have a lathe with 2 vfds, one for the spindle and one for a livetool, they are both controlled via modbus and I have made macros for the livetool and is started with m133/m134 cw/ccw (output4/5) and stopped with m135 and working fine.
But if I start the spindle and press "Stop" it stops, but if I start the livetool and press "Stop" it just keeps running, is there anyway to add a "deactivate (output4)" in the "stop" command?
Or any other way/suggestions?
Any help is appreciated.
Regards Morten
Offline TPS
  •  2,627 2,627
Re: Mach3turn Stop button?
« Reply #1 on: December 07, 2020, 02:34:13 PM »
ypo have to customize your stop button from a "normal" buttonpress to a custom macro, where you do the stopbutton and seperate DeActivate(output4).
« Reply #2 on: December 07, 2020, 02:40:58 PM »
Hi, thanks for your reply,
I can change the button to a macro and get the deactivate(output4) to work, but I can't figure out how to use the "Stop" command in a macro?
Offline TPS
  •  2,627 2,627
« Reply #3 on: December 08, 2020, 01:49:26 AM »
DoOemButton(1003)
« Reply #4 on: December 08, 2020, 02:21:03 AM »
Thanks, working superb now, thanks once again you are a life saver ;)
Regards Morten
