Hello Guest it is October 24, 2026, 12:44:53 PM
Author Topic: [CSMIO-IP/S + MACH3] using an analogue output to control an external device  (Read 129723 times)
Re: [CSMIO-IP/S + MACH3] using an analogue output to control an external device
« Reply #40 on: December 15, 2020, 07:15:50 PM »
FYI, the macropump that I used is;
SetModOutput=(81,GetUserDro(4))
« Reply #41 on: February 24, 2021, 02:40:14 AM »
I've hit into the same problem and this thread was a good hint!
But I'd like to do my bit:
maybe I did something wrong but useing untapped coordinate didn't worked in my case.
Contrary, useing any spare variable works fine. So my version of Macropump.m1s is
SetModOutput(80,GetVar(1)*409.5)
SetModOutput(81,GetVar(2)*409.5)
and G-code should contain something like
#1=5.0 #2=10.0
to setup 5V output on analog output 0 and 10V on output 1.
