Hello Guest it is October 24, 2026, 01:40:06 PM
Author Topic: [CSMIO-IP/S + MACH3] using an analogue output to control an external device  (Read 129730 times)
Offline TPS
  •  2,627 2,627
Re: [CSMIO-IP/S + MACH3] using an analogue output to control an external device
« Reply #20 on: December 02, 2020, 12:38:20 PM »
---I put B... if the value is over a certain value,
witch value?
Offline TPS
  •  2,627 2,627
« Reply #21 on: December 02, 2020, 12:41:30 PM »
Hi Tom,
Thank you for your information.
I meant the value of the GetOemDro(804).
Your assumption is that its range is 1-1000. But, where can we set that range?
Is it like a default value?
see it like a virtual axis there is no range to define, only Thing is to Zero it before you start.
« Reply #22 on: December 02, 2020, 12:53:37 PM »
Hi Tom,
I managed to make the analog output work using macropump.
All thanks to your help!!
A funny thing is happening to the B-axis. Please see the video below.
https://youtu.be/BgLlfBCSrEA
The motor setting is also attached.
Do you know what the problem is?
With the motor setting, B1 output GetOemDRO value 1.
The problem is when I changed the value too much in a time, the value was just screwed up.
And do you know the G-code to set the OmeDRO to be zero?
Best Regards,
Eric.
« Last Edit: December 02, 2020, 12:55:37 PM by razer00 »
Offline TPS
  •  2,627 2,627
« Reply #23 on: December 02, 2020, 01:04:10 PM »
with
Code: [Select]
SetModOutput(81,GetOemDro(804)*4.095)
the value is scaled to 0-100 not to 0-1000
for 0-1000 use
Code: [Select]
SetModOutput(81,GetOemDro(804)*0.4095)
to set b axis to Zero use
Code: [Select]
SetOemDro(804,0)
« Reply #24 on: December 03, 2020, 06:16:53 AM »
Hi Tom,
I encounter another problem. Never going smoothly.
As soon as B... command is input (using macropump), the whole motion stops.
Any thought?
Best Regards,
Eric.
Offline TPS
  •  2,627 2,627
« Reply #25 on: December 03, 2020, 06:47:01 AM »
a
G1 X100 Y100 B100 F50
G1 X0 Y0 B0
should not stop Motion
metric if in imperial use suitable values
« Reply #26 on: December 03, 2020, 07:16:27 AM »
The problem is that the DRO values in the display change, but the actual motion stops when the B... command is used.
Offline TPS
  •  2,627 2,627
« Reply #27 on: December 03, 2020, 07:18:20 AM »
is the b axis enabled and assigned in CSLAB plugin?
« Reply #28 on: December 06, 2020, 09:00:53 AM »
Hi Tom,
The problem is still unsolved.
I've used the following G-code.
G90
G0 X0 Y0 B0
M7
M9
G1
X 26.0 Y 0 B 19.5 F 300
X 27.0 Y 0 B 39.0 F 300
X 28.0 Y 0 B 58.5 F 300
X 29.0 Y 0 B 78.0 F 300
X 30.0 Y 0 B 97.5 F 300
And the macropump.m1s was:
SetModOutput(81, GetOemDro(804))
B-axis setting was in a way that B1 command output the analog output value 1.
In theory, B4095 should output 10V. And when we checked B command on DMI, it worked.
The problem is that when we run the G-code above, as soon as B command starts being used, the motion stops.
Interestingly, the G-code still runs without any machine movement.
Best Regards,
Eric.
Offline TPS
  •  2,627 2,627
« Reply #29 on: December 06, 2020, 01:30:47 PM »
hello Eric,
tested your code here, and it is running without stopping movement.
can you pls post your prifile XML, than i will have a look.
Regards Tom.
