Hello Guest it is October 24, 2026, 02:36:11 PM
Author Topic: [CSMIO-IP/S + MACH3] using an analogue output to control an external device  (Read 129739 times)
Re: [CSMIO-IP/S + MACH3] using an analogue output to control an external device
« Reply #30 on: December 07, 2020, 07:19:15 AM »
Hi Tom,
Thank you very much. Please see the attached profile xml file.
Any advice will be really appreciated.
Best Regards,
Eric.
Offline TPS
  •  2,627 2,627
« Reply #31 on: December 07, 2020, 08:59:39 AM »
hello Eric,
in the XML you sent B-Axis is not enabled?
if enabled do not forget the Motor Tuning
i would set 10 steps/per 10000 velocity and 10000 accel, to make sure
b-axis will not slow down the other axis.
« Reply #32 on: December 07, 2020, 09:28:24 AM »
Hi Tom,
It is strange... I enabled the B-axis.
There are a few options for B-axis. I'm not sure which option was turned off.
I went to Plugin Control > CSMIOS (Config), and then tick the box for B-axis.
Is there anything else I should do?
Strangely, the Step Pin# and Dir Pin# for all axes were set to zero. Is it normal?
Best Regards,
Eric.
Offline TPS
  •  2,627 2,627
« Reply #33 on: December 07, 2020, 02:28:56 PM »
hello Eric,
Config -> Ports&Pins -> Motor Outputs -> enable B-axis
Pins will not matter because this is handled by the plugin.
Regards Tom
« Reply #34 on: December 09, 2020, 04:21:03 AM »
Hi Tom,
Yes, that was exactly how I activated the B-axis. Sorry for my confusion.
But, even when the B-axis was ticked in the Motor Outputs setting, in the xlm file the value for Motor 4 was still zero in the xlm file.
<Motor4Active>0</Motor4Active>
Interestingly, I could get the analog output well. However, the all motion stopped.
I'm trying to change the motor speed and acceleration values in the Motor Tuning menu.
I will let you know how it works.
Best Regards,
Eric.
« Reply #35 on: December 09, 2020, 09:02:40 AM »
Hi Tom,
B-axis still rotates very low. Here are the motor settings and G-code used.
X axis: steps per 101.823, velocity 4000.2, acceleration 200
Y axis: steps per 101.795, velocity 4000.2, acceleration 750
B axis: steps per 100, velocity 10002, acceleration 10000
G90
G0 X0 Y0 B0
M7
M9
G1
X 26.0 Y 0 B 19.5 F 300
X 27.0 Y 0 B 39.0 F 300
X 28.0 Y 0 B 58.5 F 300
X 29.0 Y 0 B 78.0 F 300
X 30.0 Y 0 B 97.5 F 300
Offline TPS
  •  2,627 2,627
« Reply #36 on: December 09, 2020, 09:14:22 AM »
hi,
if i run your test here with all axis in Zero it takes about 21s.
« Reply #37 on: December 09, 2020, 09:23:05 AM »
That is a really slow speed.
The linear speed (F300) should be 5 mm/sec.
Since the linear distance along X is only 4 mm, it should take only 1 sec?
I've removed the B... command and ran the code again.
The movement is much faster.
I don't quite understand what B-axis setting is wrong.
Offline TPS
  •  2,627 2,627
« Reply #38 on: December 09, 2020, 09:30:39 AM »
in G1 move all axis start and stop together
B-Axis has 97mm to go, so it is about 20s.
and the x-move is 30mm, you start from X0
« Last Edit: December 09, 2020, 09:38:06 AM by TPS »
« Reply #39 on: December 14, 2020, 07:32:05 PM »
Hi Tom,
Finally, I managed to solve the problem.
The critical thing was to use G93 command, which let the machine finish all axes movement in a specific time.
All working now... Thanks a lot for your help so far!!
Best Regards,
Eric.
