Hello Guest it is November 13, 2026, 12:01:03 PM
Author Topic: Looking for good DIY controller kit supplier  (Read 338169 times)
Re: Looking for good DIY controller kit supplier
« Reply #20 on: November 20, 2020, 08:08:45 PM »
Thanks, so that means that the resistance between wires 5 and 1, 5/2, 5/3 and 5/4 would be the same, while the resistances between other combinations (i.e. 1/2, 2/4 etc) would differ.
I did read somewhere in Lin Engineering that the hybrid 6 wire 5718L series motors (my motors) can be connected as either a unipolar 6 wire or bipolar 5 wire but cannot find the references anymore. Will go looking.
I'll check the wire harness to see if wire config has been changed between the motors and the board.
Offline MN300
  •  306 306
« Reply #21 on: November 20, 2020, 08:32:28 PM »
I am waiting to hear what the winding resistance is. Also a few voltage checks would be of interest. With the drives enabled would you please measure the voltage from ground to pins 1,2,3 and 4?. If you have a basic stepper drive two pins will be the nominal supply voltage, about 17.5V and the other two will measure about a volt.
« Reply #22 on: November 20, 2020, 09:17:47 PM »
Hi MN300
My friend with the multimeter, but most importantly, 'know how', will be here most likely Monday, possibly tomorrow. We live remotely here so have to travel some distance to meet. I'll have all the data then. Will definitely also look at the voltages as suggested by you. Also the harness configuration.
« Reply #23 on: November 21, 2020, 12:22:40 AM »
Hope this gets there
« Reply #24 on: November 21, 2020, 12:31:35 AM »
Yup, it did.
I checked the harness. The brown wire is a separate circuit board to motor casing/CNC frame earth and does not come out of the motor. The motor is a standard Lin Engineering colour code 1 with a yellow wire (pls view last attachment). The white and yellow wires are combined and insert into TPS' 5th pin into the board.
I have not as yet found the reference to wiring the 6 wire 5718L motor to 5 wires; still looking.
So does that mean that pin 5 yellow and white are the centre taps?
Also, does the motor now function as a bipolar?
« Reply #25 on: November 21, 2020, 12:41:26 AM »
Found the reference to wiring 6 as a 5 wire
Offline TPS
  •  2,627 2,627
« Reply #26 on: November 21, 2020, 01:46:37 AM »
just for swapping the axis that is all.
to have a "deeper" look into your configuration pls post your Profile XML file.
« Reply #27 on: November 21, 2020, 03:54:48 AM »
My attempts at attachments keep on showing errors, I'll try again
« Reply #28 on: November 21, 2020, 03:55:39 AM »
« Reply #29 on: November 21, 2020, 03:58:02 AM »
Worked this time. I have to thank you (TPS) and MN300 for your time and effort, it's invaluable. I'm on a steep learning curve and couldn't do it without you.
You have my kindest regards
