Hello
Guest
it is
October 04, 2026, 10:42:40 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
G-Code, CAD, and CAM
G-Code, CAD, and CAM discussions
Question on coordinate system offsets
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Question on coordinate system offsets (Read 20269 times)
stab01
2
on:
November 13, 2020, 09:59:10 AM »
Hi all,
I want to mill two equal objects in one piece of wood, which means repetition of gcode.
I'd like to change the work offset and then just copy the gcode.
Is that possible and what would the g-code command be?
I'm using Mach3.
Regards
stab01
Last Edit: November 13, 2020, 10:01:21 AM by stab01
Tweakie.CNC
9,374
Super Kitty
Re: Question on coordinate system offsets
Reply #1 on:
November 14, 2020, 12:06:05 AM »
There is more than one way of achieving this type of offset machining and Roger has explained in detail those methods in his .pdf document which you can download from here;
https://www.machsupport.com/forum/index.php?topic=33595.0
Hope this helps.
stab01
2
Reply #2 on:
November 14, 2020, 01:51:37 AM »
Thank you for this link
/stab01
Print
Pages:
1
Go Up
« previous
next »
