Hello
Guest
it is
November 19, 2026, 06:16:55 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
G-Code, CAD, and CAM
G-Code, CAD, and CAM discussions
Question on coordinate system offsets
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Question on coordinate system offsets (Read 20532 times)
stab01
2
on:
November 13, 2020, 09:59:10 AM »
Hi all,
I want to mill two equal objects in one piece of wood, which means repetition of gcode.
I'd like to change the work offset and then just copy the gcode.
Is that possible and what would the g-code command be?
I'm using Mach3.
Regards
stab01
Last Edit: November 13, 2020, 10:01:21 AM by stab01
Logged
Tweakie.CNC
9,378
Super Kitty
Re: Question on coordinate system offsets
Reply #1 on:
November 14, 2020, 12:06:05 AM »
There is more than one way of achieving this type of offset machining and Roger has explained in detail those methods in his .pdf document which you can download from here;
https://www.machsupport.com/forum/index.php?topic=33595.0
Hope this helps.
Logged
stab01
2
Reply #2 on:
November 14, 2020, 01:51:37 AM »
Thank you for this link
/stab01
Logged
Print
Pages:
1
Go Up
« previous
next »
