Hello Guest it is September 03, 2026, 09:42:17 AM
Author Topic: Very Slow Feed Rate  (Read 12196 times)
Very Slow Feed Rate
« on: November 11, 2020, 07:21:52 PM »
Hello People, I have calibrated and tuned my CNC steppers and the CNC now jogs beautifully. Once the sample G Code (roadrunner) is loaded and the Cycle Start button is activated however, the Feed Rate is extremely slow, often only a step and very small distance at the time. Over-Riding the Feed Rate by 250% makes hardly any difference. My CNC is a 12 year old MiniMax (MaxPath42) with recon control circuitry. It has another issue but I'll discuss that separately. Has anyone found a solution to this problem?
Offline TPS
  •  2,627 2,627
Re: Very Slow Feed Rate
« Reply #1 on: November 12, 2020, 05:02:46 AM »
for a simple test use MDI Input
metic -> G1X100 F100 should take 1 Minute
imperial -> G1X10 F10 should take 1 Minute
if x axis is at 0 when You start
« Reply #2 on: November 12, 2020, 09:24:20 AM »
I'm having the same problem, mach was working till I reloaded it and must have changed something. Works fine in jog, but 1" on DRO is about 12" on mach. Not sure what a MDI input is
« Reply #3 on: November 12, 2020, 03:59:07 PM »
Thanks TPS, will try MDI (manual data input) and see what happens. Will report back.
« Reply #4 on: November 12, 2020, 04:30:32 PM »
It worked, almost to the milli second. Thanks again TPS. Does that mean that my CNC is a very slow machine, as I have seen another that seems to fly through the job.
Hi dannyb, the MDI tab is next to the Program Run tab and allows for manual code entry. Your issue looks like a calibration issue though, could that be the case.
« Reply #5 on: November 12, 2020, 06:01:59 PM »
By the way TPS, what is the Feed Rate diagnostic code and timing for the Z axis?
Offline TPS
  •  2,627 2,627
« Reply #6 on: November 13, 2020, 01:21:32 AM »
the code for Z axis would be
metic -> G1Z-100 F100 should take 1 Minute
imperial -> G1Z-10 F10 should take 1 Minute
drive the z axis all the way up and Zero it
pls post screenshots of motortunig Windows off all three axis and we will see.
« Reply #7 on: November 13, 2020, 02:42:00 AM »
Would do if I could TPS, but in the mean time my X axis stepper or controller has blown up. Motor very hot with circuitry plastic burn smell coming from either the controller or the motor itself. Back to the drawing board.  Wish you all the best and I'll be back once this has been resolved.
