Hello Guest it is November 22, 2026, 02:03:58 PM
Author Topic: Problem with % SRO Mach3  (Read 9293 times)
« on: October 29, 2020, 07:04:37 AM »
Hello good day, I wanted to make a question about my WMD45 milling machine converted to CNC.
It has CSMIO IP / M controller board with closed loop nema 34 motors and I use mach3.
I am doing the installation of a variable frequency drive to be able to control the speed of the spindle motor (4 poles, 380V, 1500 rpm, 1.5 hp).
I already did the installation according to the diagram provided by CSLABS, until then I had no problems. The problem I have is that when varying the% SRO in Mach3, the revolutions goes from 1% to 94% (when reaching 94 the rpm is 1500), from 95 to 100% there are no changes.
This makes for example take the RPM to 50% instead of going to 750rpm it goes 790. It is as if the last 5% did not count.
Something similar happened to someone or know how to configure it?
Offline TPS
  •  2,627 2,627
Re: Problem with % SRO Mach3
« Reply #1 on: October 30, 2020, 03:13:02 AM »
i assume you are using a analog Output for Speed control.
you can go to Plugin Control -> CSMIO and then to Analog IO
here you can watch the voltage of your Analog Output and check the value.
« Reply #2 on: October 30, 2020, 06:11:53 AM »
Hello, yes, I use an analog output.
I Check the Analog IO in the plugin
Analog output voltage does not reach full when SRO is 94%, but the motor goes to 100%
Offline TPS
  •  2,627 2,627
« Reply #3 on: October 30, 2020, 07:59:52 AM »
then the Problem is on your frequency converter.
