Hello
Guest
it is
November 01, 2026, 10:02:44 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
G-Code, CAD, and CAM
LazyCam (Beta)
Modifying F value in file exported to Gcode folder
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Modifying F value in file exported to Gcode folder (Read 61857 times)
ionapostol
18
on:
October 27, 2020, 05:13:02 AM »
I know is a piece of antique but I'll ask anyway.
I play with LazyCam 3.00 and in exported file is an F1.00 and every time I must change it to my needs by editing that file.
Is there a way to modify this and remain that way?
Tweakie.CNC
9,375
Super Kitty
Re: Modifying F value in file exported to Gcode folder
Reply #1 on:
October 27, 2020, 05:53:25 AM »
You need to set-up the Tool and its parameters in the Layers Menu which can then be saved.
Rich's LazyCam Manual explains;
https://www.machsupport.com/forum/index.php?topic=12078.msg77415#msg77415
ionapostol
18
Reply #2 on:
October 27, 2020, 08:05:37 AM »
I tried but output file shows F1.00
I create a new tool , put feed value to 380 and...open a dxf clean it and save the .tap file but the F is still 1.00.
I don`t know what to do...
ionapostol
18
Reply #3 on:
June 16, 2021, 05:10:15 AM »
I try everithing but lazy cam post to mach3 only at F1 feed rate, see atached image:
Print
Pages:
1
Go Up
« previous
next »
