G-Code, CAD, and CAM => LazyCam (Beta) => Topic started by: ionapostol on October 27, 2020, 06:13:02 AM
Title: Modifying F value in file exported to Gcode folder
Post by: ionapostol on October 27, 2020, 06:13:02 AM
I know is a piece of antique but I'll ask anyway.
I play with LazyCam 3.00 and in exported file is an F1.00 and every time I must change it to my needs by editing that file.
Is there a way to modify this and remain that way?
Title: Re: Modifying F value in file exported to Gcode folder
Post by: Tweakie.CNC on October 27, 2020, 06:53:25 AM
You need to set-up the Tool and its parameters in the Layers Menu which can then be saved.
Rich's LazyCam Manual explains; https://www.machsupport.com/forum/index.php?topic=12078.msg77415#msg77415
Post by: ionapostol on October 27, 2020, 09:05:37 AM
I tried but output file shows F1.00   :-[
I create a new tool , put feed value to 380 and...open a dxf clean it and save the .tap file but the F is still 1.00.
I don`t know what to do...
Post by: ionapostol on June 16, 2021, 06:10:15 AM
I try everithing but lazy cam post to mach3 only at F1 feed rate, see atached image:
