Hello Guest it is November 22, 2026, 02:04:10 PM
Author Topic: Run Batch G-Code with hold between files  (Read 12666 times)
« on: October 24, 2020, 02:58:49 AM »
Hi All;
I am very new to Mach3 and was hoping that someone could assist me with a problem I need to solve.
I have 120 files that I need to run in sequence using a fixture.  Each file is only run once.
After each file, a part needs to be removed from the fixture and the new part inserted.
What I would like to do is:
1) have Mach3 open the first file
2) Wait for the Cycle Start button to be pressed
3) Run the G-Code
4) Hold for the milled part to be removed
5) Open file 2
6) Wait for the Cycle Start Button to be pressed (allows for a new blank to be loaded)
7) Run G-code for file 2
rinse repeat...
Is there a way that this can easily be done?
Thanks for the assistance!
Mike
Re: Run Batch G-Code with hold between files
« Reply #1 on: October 24, 2020, 07:01:23 PM »
Are all 120 files the same or are they 120 different parts ?
« Reply #2 on: October 24, 2020, 10:58:04 PM »
Hi TP;
Thanks for the quick reply.  I will have 120 unique files.  I haven't set the file name structure yet so I can set that according to the solution if needed.
Mike
« Reply #3 on: October 25, 2020, 04:31:32 PM »
OK the easy way is to assemble all 120 files into 1 file with a M00 in between each section. You WOULD need to remove any M30 from the end of each file except for the end of the complete file.
Another way would be to program them as Subroutines calling each file in order and again adding a M00 at the end of each subroutine.
Another way is to try a Macro program that calls each file as an indivdual file in the order of run.
There can be quirks with each style. Things like IF you actually need to see the toolpath for each file.
Just a thought , (;-) TP
« Reply #4 on: October 25, 2020, 09:55:26 PM »
Hi TP;
If I want to write them as a Subroutines, how would I go about doing it?
A macro might also be a good way to do it.  What programming language would it need to be in?
Mike
Offline TPS
  •  2,627 2,627
« Reply #5 on: October 26, 2020, 01:43:10 AM »
how to run Subroutines is explained here: https://www.machsupport.com/forum/index.php?topic=7684.0
macro language will be VB
example to run files with different names:
Code: [Select]
Sub Main()
LoadRun("C:\Mach3\Gcode\file1234.tap")
Code "M00"
LoadRun("C:\Mach3\Gcode\fileabc.tap")
'and so on
Code"M30"
End Sub
example if file names are numbered:
Code: [Select]
Sub Main()
   For i = 1 To 120
LoadRun("C:\Mach3\Gcode\file" & i & ".tap")
If i <> 120 Then
Code "M00"
Else
Code"M30"
End If
   Next i
End Sub
code example not tested just written down.
