Hello Guest it is November 22, 2026, 02:04:04 PM
Author Topic: Mach3 How to use A Axis(Stepper) as Spindle?  (Read 9855 times)
« on: October 15, 2020, 08:18:56 AM »
hi!
i have bought a rnr motion control eco v2 usb unit.
this unit not support dir/step on spindle.
now i want to use my A Axis as Spindle.
my A Axis is a Nema34.
i know that a stepper is not a good choice.
i want to test something and play arround.
i read that SwapAxis(3,6) change the A Axis to Spindle.
but if i enter this in the commandline in Mach3 i got an error.
how is the swapAxis function to use?
where do i enter it?
thanks
Offline TPS
  •  2,627 2,627
Re: Mach3 How to use A Axis(Stepper) as Spindle?
« Reply #1 on: October 16, 2020, 12:41:24 AM »
it is to use in a VBScript.
Operator -> VB Script Editor
« Reply #2 on: October 16, 2020, 09:00:57 AM »
thanks! but now... i dont know how to write this script that it work.... i am absolute new with mach3.
can you show me a example please?
thanks
« Reply #3 on: October 16, 2020, 11:56:05 AM »
Where did you read that you can swap axis with the spindle ?? The spindle is not classed as an axis so I do not believe what you want to do is possible in Mach3. Even IF it worked when you swapped you would NOT have a normal spindle operation. I have done cylindrical grinding AND offset grinding (cam grinding ) with mach3 but it takes special considerations in scripting(macros) and CAM to make it all work.
Just a thought, (;-) TP
« Reply #4 on: October 17, 2020, 09:10:39 AM »
i read it in some threads and see it in a video.
for me its interesting to drive AAxis as Spindle.
can someone please explain me?
thanks
