Hello Guest it is October 23, 2026, 04:27:24 AM
Author Topic: Ouput not working in tool change when output also in macropump  (Read 11320 times)
« on: October 12, 2020, 10:14:18 AM »
I have an output that is working with pushbutton latching when pressed. That is working fine. push button and the poutput comes on. {Push again and output goes off. that is all working.
That output raises the dust collector shoe.
The first thing my ATC does is raise the dust shoe.  If I delete the macropump it works in the atc. If I use the macropump macro what happens is the macropump is checking the input, and when the atc fires the output the macro turns it off right away.
I see this working the way I programmed it which is wrong. IS there a way to check if the atc macro is running so I can add it to the macropump as a way for it to bypass shutting it dpown again?
Something like if input1 isactive and atcmacro not running fire output.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Ouput not working in tool change when output also in macropump
« Reply #1 on: October 12, 2020, 12:43:22 PM »
It might be better to set your button up as an OEMTrigger, see Mach3Mill_Install_Config.PDF section 4.13 for details.
« Last Edit: October 12, 2020, 12:45:21 PM by Graham Waterworth »
Offline TPS
  •  2,627 2,627
« Reply #2 on: October 13, 2020, 02:10:30 AM »
simply set a OEMLed in your ATC macro, then macropump is able to check, that ATC macro whants to set the Output
and enable it.
« Reply #3 on: October 13, 2020, 07:28:47 AM »
So would this work? Can I have two and's on a conditional statement?
This is depending on when ATC runs I turn on OEMLED(13) and turn it off when the TC is completed.
If Not IsActive (Input1)  = True Then
  LED = GetOEMLED(77)  ' LED looks at state of Output 5 LED
End If
If IsActive (Input1) And LED = True And OEMLED(13) = False Then  ' looking at input 1 and LED of Output 4 and OEMLED(13)
  DeActivateSignal (OutPut4)
Else
 If IsActive (Input1) And LED = False And OEMLED(13) = False Then
 End If
End If
If Not IsActive (Input2)  = True Then
  LED2 = GetOEMLED(78)  ' LED looks at state of Output 5 LED
End If
If IsActive (Input2) And LED2 = True Then  ' looking at input 1 and LED of Output 5
  DeActivateSignal (OutPut5)
Else
 If IsActive (Input2) And LED2 = False Then
 End If
End If
Offline TPS
  •  2,627 2,627
« Reply #4 on: October 13, 2020, 07:36:23 AM »
this is one way of many's. do not use OEMLED(13) it is Flood LED
use 1200 and abofe
« Reply #5 on: October 13, 2020, 08:56:01 AM »
I thought I could use it since this is a router and wont use coolant. plus it would give me a visual indication of ATC in progress.
But I understand your concerns.
« Reply #6 on: October 13, 2020, 10:26:17 AM »
use 1200 and abofe
OK that works, thanks
Bob
