Mach Discussion => General Mach Discussion => Topic started by: bevins on October 12, 2020, 11:14:18 AM
I have an output that is working with pushbutton latching when pressed. That is working fine. push button and the poutput comes on. {Push again and output goes off. that is all working.
That output raises the dust collector shoe.
The first thing my ATC does is raise the dust shoe. If I delete the macropump it works in the atc. If I use the macropump macro what happens is the macropump is checking the input, and when the atc fires the output the macro turns it off right away.
I see this working the way I programmed it which is wrong. IS there a way to check if the atc macro is running so I can add it to the macropump as a way for it to bypass shutting it dpown again?
Something like if input1 isactive and atcmacro not running fire output.
It might be better to set your button up as an OEMTrigger, see Mach3Mill_Install_Config.PDF section 4.13 for details.
simply set a OEMLed in your ATC macro, then macropump is able to check, that ATC macro whants to set the Output
and enable it.
So would this work? Can I have two and's on a conditional statement?
This is depending on when ATC runs I turn on OEMLED(13) and turn it off when the TC is completed.
If Not IsActive (Input1) = True Then
LED = GetOEMLED(77) ' LED looks at state of Output 5 LED
End If
If IsActive (Input1) And LED = True And OEMLED(13) = False Then ' looking at input 1 and LED of Output 4 and OEMLED(13)
DeActivateSignal (OutPut4)
Else
If IsActive (Input1) And LED = False And OEMLED(13) = False Then
End If
End If
If Not IsActive (Input2) = True Then
LED2 = GetOEMLED(78) ' LED looks at state of Output 5 LED
End If
If IsActive (Input2) And LED2 = True Then ' looking at input 1 and LED of Output 5
DeActivateSignal (OutPut5)
Else
If IsActive (Input2) And LED2 = False Then
End If
End If
this is one way of many's. do not use OEMLED(13) it is Flood LED
use 1200 and abofe
I thought I could use it since this is a router and wont use coolant. plus it would give me a visual indication of ATC in progress.
But I understand your concerns.
use 1200 and abofe
OK that works, thanks
Bob
