Hello Guest it is October 20, 2026, 03:53:48 PM
Author Topic: How to get rid of pauses between different segments of a program  (Read 10905 times)
A project I am working has 6 different sections.  There is one tool change and I do separate the sections for that.  I have saved the files that use the same tool together and want to run those as a single continuous program but when I do so there are pauses that I don't want.  I guess the question is, what commands do I remove to get it run non stop?  When I bring up the programs to edit them I can see where the programs change but I do not know what to info  :-\remove, if I even can.  What this means is I can't leave the machine to run to program completion.
  •  9,374 9,374
Re: How to get rid of pauses between different segments of a program
« Reply #1 on: October 03, 2020, 12:21:51 AM »
Zip and post your problem Gcode file then we should be able to resolve the issue.
« Reply #2 on: October 03, 2020, 01:18:33 PM »
As per request I have zipped the programs I want to run seamlessly instead of pausing between each section...
« Last Edit: October 03, 2020, 08:37:28 PM by Graham Waterworth »
  •  9,374 9,374
« Reply #3 on: October 04, 2020, 02:56:31 AM »
Looks like your .zip file was edited out - could you perhaps try again.
« Reply #4 on: October 04, 2020, 10:24:25 PM »
Here is the zip file...
  •  9,374 9,374
« Reply #5 on: October 05, 2020, 12:52:51 AM »
You attached an .exe file which was deleted.
Please .zip your problem Gcode file and attach it as a .zip file.
