Mach Discussion => General Mach Discussion => Topic started by: BillC on October 02, 2020, 10:10:15 AM
A project I am working has 6 different sections. There is one tool change and I do separate the sections for that. I have saved the files that use the same tool together and want to run those as a single continuous program but when I do so there are pauses that I don't want. I guess the question is, what commands do I remove to get it run non stop? When I bring up the programs to edit them I can see where the programs change but I do not know what to info :-\remove, if I even can. What this means is I can't leave the machine to run to program completion.
Zip and post your problem Gcode file then we should be able to resolve the issue.
As per request I have zipped the programs I want to run seamlessly instead of pausing between each section...
Looks like your .zip file was edited out - could you perhaps try again.
Here is the zip file...
You attached an .exe file which was deleted.
Please .zip your problem Gcode file and attach it as a .zip file.
