Hello Guest it is November 07, 2026, 02:55:44 AM
Author Topic: Mach 3 Jog Mode in Step is Excruciating Slow  (Read 6747 times)
« on: September 30, 2020, 07:37:25 PM »
I am running Mach3 with a Warp9 Ethernet SmoothStepper and C25 BOB.
When I select the jog mode to Step and jog it is incredibly slow.  I have the Jog Rate set to 100%.
When I jog using the keys or the buttons on the onscreen pendant in "Cont" mode it jogs at the correct speed.(3048 mm/min)
When I set it to "Step" it is moving incredibly slow.
What is going on?  I had no problem before reinstalling the software after I switched my controller card to the Smoothstepper.  I reinstalled it to have a clean setup for the smoothstepper.
Am I missing something?
Please help!!
Thank you
Mark
Offline reuelt
  •  520 520
Re: Mach 3 Jog Mode in Step is Excruciating Slow
« Reply #1 on: September 30, 2020, 09:20:21 PM »
I thought with ESS you need to hold down the shift-key to be about to jog properly
Read Warp9 FAQ
https://www.warp9td.com/index.php/faq/faq-mach3#KeyboardJogging
"the gift of God is eternal life through Jesus Christ our Lord"
« Reply #2 on: October 01, 2020, 01:33:36 PM »
Read Warp9 FAQ
I can jog in continuous mode just fine,  In Step Mode it jogs but VEY VERY slowly with and without the Shift Key.
I  also found that it is not all the time.  I can get it to jog after running a cut file.
