Hello Guest it is November 22, 2026, 08:12:55 AM
Author Topic: Mach3 Gcode movement help  (Read 10996 times)
« on: September 25, 2020, 11:30:54 AM »
i have just installed Mach3 on a new computer running window 7   this mach3 program was moved from my old computer  that stopped working.
after i installed the program and get the motors tuned  i tried running a gcode file  and nothing happen.
The DRO moves but no movement  on the motors.
All three axis move if i am moving them using the keyboard keys.
Thanks for any help
Offline reuelt
  •  520 520
Re: Mach3 Gcode movement help
« Reply #1 on: September 25, 2020, 04:46:53 PM »
Thanks for any help
Not enough information given for people to help
But first rule out these:-
1. Work coordinates G54  is not yet defined so your motors cannot move outside of limits?
2. There is no F statement?
3. Gcode file is in mm without but G21 when your machine is in inches?
4. A rotary axis (like A or B or C) not correctly defined?
5. Reset button not pressed and {ref all home] not yet done?
6. Charge pump or enable signal not correct?
7. Soft limits triggered or limit switch triggered?
8. Fuse in control box has blown?
9. Axis set in wrong direction?
« Last Edit: September 25, 2020, 04:48:32 PM by reuelt »
"the gift of God is eternal life through Jesus Christ our Lord"
« Reply #2 on: September 25, 2020, 06:00:56 PM »
Thanks for your reply.
I found out the cause of the problem.   it was the mach3 cycle start   for all the years i been using Mach3 i only needed to press the cycle start button once to get the file cutting.  just by accident or frustration i press  the cycle start twice and the file started cutting.
Pressing once just started the timer going.
not sure why   any idea why?
Offline reuelt
  •  520 520
« Reply #3 on: September 25, 2020, 06:46:42 PM »
Could there be a pause e.g for manual tool change in the program that requires another [cycle start]?
Offline TPS
  •  2,627 2,627
« Reply #4 on: September 26, 2020, 03:27:53 AM »
check  Config -> General Config -> Tool Change
what is selected there?
« Reply #5 on: September 28, 2020, 09:13:57 AM »
Stop spindle wait for cycle start.
is selected.
Offline TPS
  •  2,627 2,627
« Reply #6 on: September 29, 2020, 01:28:51 AM »
then i expect, that there is a M6Tsomething at the beginning of your code.
