Hello
Guest
it is
November 07, 2026, 04:13:51 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
Mach4 General Discussion
Running G-Code slows machine
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Running G-Code slows machine (Read 8938 times)
alevitt53
27
on:
September 18, 2020, 05:12:09 PM »
CNCRounter parts 4896 with ESS controller.
Just switched to Mach4. Motors run at normal speed in jog mode.
As soon as it tries to run G-Code like test file attached, it slows to a snails pace.
Can't figure it out.
Any help appreciated
Thank you
Graham Waterworth
2,785
Yorkshire Dales, England
Re: Running G-Code slows machine
Reply #1 on:
September 19, 2020, 05:43:19 PM »
Are you in Inches or MM?
alevitt53
27
Reply #2 on:
September 19, 2020, 05:44:36 PM »
inches
Also, if I run it line by line in the MDI window, it runs proper speed
Last Edit: September 19, 2020, 05:48:12 PM by alevitt53
Graham Waterworth
2,785
Reply #3 on:
September 19, 2020, 06:00:53 PM »
The code looks ok so it must be on override that is active.
alevitt53
27
Reply #4 on:
September 19, 2020, 06:02:17 PM »
Do you have a hint where I might find that?
reuelt
520
Reply #5 on:
September 21, 2020, 06:17:21 PM »
Quote from: alevitt53 on September 19, 2020, 06:02:17 PM
See attached. Click on 100% and 100%
or temporarily add
M49
at the beginning of the tap file to see if speed becomes normal.
"the gift of God is eternal life through Jesus Christ our Lord"
alevitt53
27
Reply #6 on:
September 21, 2020, 06:56:49 PM »
Thanks for everyone's response. It turns out the motor tuning on the A axis was so slow that everything else slowed to catch up to it. Once I got the motor close to proper tuning, everything ran smoothly.
Print
Pages:
1
Go Up
« previous
next »
