Hello Guest it is November 23, 2026, 03:12:25 PM
Author Topic: mach3 text engraving issues  (Read 7948 times)
« on: September 09, 2020, 01:31:56 PM »
ive been using the text engraving wizard on mach 3 loader and its been working.
now when I set everything and type what I want engraved and hit cycle start it moves in the y axis where it needs to be then drops down past where I set my z and goes an inch or so into the board im engraving. any suggestions on what is wrong and how to fix it ?
  •  9,378 9,378
Re: mach3 text engraving issues
« Reply #1 on: September 10, 2020, 12:03:53 AM »
Could you perhaps attach your problem Gcode file.
« Reply #2 on: September 10, 2020, 09:22:09 AM »
After re checking my settings probably 100 times I finally figured out the z top setting was wrong. but thanks for the reply
