Hello Guest it is November 22, 2026, 10:17:14 AM
Author Topic: touch probe install on mack 3  (Read 8440 times)
Offline jon b
  •  22 22
« on: August 30, 2020, 05:38:30 AM »
Hi i am installing a touch probe on my cnc its all wired up and functions just need to enter the script and should be good to go ,however i do not have a homing switch on my Z axis to set zero home position ? im guessing this is required for the touch probe to work or am i wrong
measure twice cut once !! so why is my bin always full
  •  9,378 9,378
Re: touch probe install on mack 3
« Reply #1 on: August 30, 2020, 05:45:49 AM »
A touch probe is used to set to set the tool in relation to the work surface (usually Z zero at the work surface) so Z homing is not required.
Offline jon b
  •  22 22
« Reply #2 on: August 30, 2020, 05:59:58 AM »
Thanks Tweakie
just checking don't know why i had a senior moment  ::) so as long as z zero is set up to table surface good to go ? . I have this already set in soft limits ...
Thank you
  •  9,378 9,378
« Reply #3 on: August 30, 2020, 06:40:13 AM »
Just a note...
Z zero is usually set at the top surface of the work rather than the table surface. This way +Z is above the initial work surface and -Z is below the initial work surface.
