Hello Guest it is October 25, 2026, 04:03:06 AM
Author Topic: z inhibit / max z depth  (Read 8688 times)
Offline Bill_O
  •  615 615
« on: August 26, 2020, 04:18:38 PM »
Is there a function in Mach4 that will limit how deep the z axis will move?
I think there was one in Mach3 but I never used it.
Bill
Offline dws
  •  24 24
Re: z inhibit / max z depth
« Reply #1 on: August 26, 2020, 06:59:28 PM »
One way to do this is too set your soft limits for the Z-axis.
David
Offline Bill_O
  •  615 615
« Reply #2 on: August 27, 2020, 07:25:49 AM »
David,
I thought about that but it looked like that only worked for jogging or if in a program would stop if the file went outside the limits.
I will give it a try and see what happens.
Thank you.
Bill
Offline smurph
  •  1,575 1,575
« Reply #3 on: September 01, 2020, 12:36:57 AM »
Set parameter 1801 to the minimum Z depth.  The default is NIL, or no minimum Z depth.
You can do this with G10 L50 or just modify the parmaeters.ini file when Mach is not running.
[1801]
Desc=Mnimum Z level
Type=2
Value=-2.00
Steve
Offline Bill_O
  •  615 615
« Reply #4 on: September 01, 2020, 09:34:23 AM »
Thanks.
I will give it a try.
Bill
Offline Bill_O
  •  615 615
« Reply #5 on: September 03, 2020, 07:50:50 AM »
It works great.
Thank you.
Bill
