Hello
Guest
it is
October 25, 2026, 03:16:22 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach4 General Discussion
z inhibit / max z depth
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: z inhibit / max z depth (Read 8683 times)
Bill_O
615
on:
August 26, 2020, 04:18:38 PM »
Is there a function in Mach4 that will limit how deep the z axis will move?
I think there was one in Mach3 but I never used it.
Bill
Logged
dws
24
Re: z inhibit / max z depth
Reply #1 on:
August 26, 2020, 06:59:28 PM »
One way to do this is too set your soft limits for the Z-axis.
Logged
David
Bill_O
615
Reply #2 on:
August 27, 2020, 07:25:49 AM »
David,
I thought about that but it looked like that only worked for jogging or if in a program would stop if the file went outside the limits.
I will give it a try and see what happens.
Thank you.
Bill
Logged
smurph
1,575
"That there... that's an RV."
Reply #3 on:
September 01, 2020, 12:36:57 AM »
Set parameter 1801 to the minimum Z depth. The default is NIL, or no minimum Z depth.
You can do this with G10 L50 or just modify the parmaeters.ini file when Mach is not running.
[1801]
Desc=Mnimum Z level
Type=2
Value=-2.00
Steve
Logged
Bill_O
615
Reply #4 on:
September 01, 2020, 09:34:23 AM »
Thanks.
I will give it a try.
Bill
Logged
Bill_O
615
Reply #5 on:
September 03, 2020, 07:50:50 AM »
It works great.
Thank you.
Bill
Logged
Print
Pages:
1
Go Up
« previous
next »
