Hello Guest it is October 21, 2026, 09:49:05 AM
Author Topic: RnR R08 ECO MOTION 2.0 + Spindle Motor - Connection  (Read 10269 times)
« on: August 26, 2020, 11:02:15 AM »
Hi guys good morning!
I need a help to make the connection and activation on the correct pins.
I connected to the tutorial below, also using the third source with 10v. But I don't know how to connect the OUT outputs to trigger the spindle.
Thanks for the opportunity.
Offline reuelt
  •  520 520
Re: RnR R08 ECO MOTION 2.0 + Spindle Motor - Connection
« Reply #1 on: September 12, 2020, 05:54:20 PM »
Your RnR USB ECO Motion board does not have any relay.
Either replace with another controller board that has a relay or add a $5 5V relay (designed for Arduino) to convert one of the outputs to a switch.
(see attached)
The relay can then switch on/off your spindle controller.
« Last Edit: September 12, 2020, 05:56:59 PM by reuelt »
"the gift of God is eternal life through Jesus Christ our Lord"
