Hello Guest it is November 22, 2026, 09:57:11 AM
Author Topic: I can't reset machine coordinates  (Read 7223 times)
« on: August 24, 2020, 11:53:48 PM »
I send the machine home and, after it gets there, I can zero the dros with no problem. When I press and activate the "Machine Coordinates"  button the dros are set to the the middle of the table. I try to zero with the buttons, nothing happens. Try by pressing the home button, nothing happens.
Yes I have home switches and everything else works.  Without homing the machine coordinates I can not activate the soft stops, already entered the values and activated the Y and X not the Z.
Well as a new user I need a bit of help. Thank you.
Mtabernig
  •  9,378 9,378
Re: I can't reset machine coordinates
« Reply #1 on: August 25, 2020, 12:09:21 AM »
Perhaps take a look at Roger's pdf which explains the coordinate system. It can be downloaded from here;  https://www.machsupport.com/forum/index.php?topic=33595.0
