Hello Guest it is October 23, 2026, 05:13:40 PM
Author Topic: Losing Z reference with G Code generated from Fusion360  (Read 17226 times)
« on: August 24, 2020, 12:10:12 PM »
We recently got the panel router here at the shop running and it's working great for making things flat, but any time I've produced any g-code from Fusion360 it loses its Z reference.
Sheetcam generates g-code that does not cause such issues.
I'll admit that I'm a bit out of my depth on this side of things, would anyone have any ideas about why the machine would be losing its Z ref?
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Losing Z reference with G Code generated from Fusion360
« Reply #1 on: August 24, 2020, 05:19:52 PM »
Are you talking about 3D cutting when the machine looses position, if so it could be that the motor tuning on the Z axis needs slowing down or the accel/decel needs upping to stop it loosing position.
« Reply #2 on: August 25, 2020, 05:44:24 AM »
It's losing z ref when the machine finishes a cut, retracts, rapids to the new start point, and comes down with an entirely new z ref. I've had it lose small amounts coming to something like 0.1 inches and large amounts like 4 inches. My current thought is that it's partly how the machine is setup and partly the g-code being produced.
Additional wrinkles, we are using servos rather than steppers.
Bear in mind it only does this with g-code generated from Fusion 360 and both the Mach3 and Mach4 posts have the machine do this.
« Reply #3 on: August 25, 2020, 06:34:00 AM »
from yours post sound like its some thing wrong with the pp in Fusion 360
try send sample of small nc file that work good and one sample that make that error
try both will be with same tool and same cuting depth ,so we can try help here
« Reply #4 on: August 25, 2020, 08:43:20 AM »
Here you go,
« Reply #5 on: August 25, 2020, 09:34:05 AM »
i don't know which file work which not but i see 2 different
1. nc files the z top its 0.3937 while in tap file its 0.2
2. tap file you have in each time go to z the command S5903  i don't know what is this mean?
3. nc file height correction line its"G43 H103"   while in tap its "G43 Z0.6 H1"  why this z in the line?
« Reply #6 on: August 25, 2020, 12:13:43 PM »
Here's what I can clarify and answer,
1. The .nc file is generated by Sheetcam, the .tap files were generated by Fusion360 using their published post processors.
2. The Z axis on the machine has about 12" total travel and the stock is usually between 2-4" in height, so having retracts at that height are not a problem.
3. The tool used in Fusion for this sample had a spindle speed of 5093 RPM, so I suspect that is the Fusion post being very redundant and setting the spindle speed again.
4. I have no idea why there would be any tool height correction (G43) in the g-code for either the .nc or .tap files. I suspect that tap file is essentially saying move the tool up 0.6 inches plus the height listed in H1.
I'll admit to a moderate degree of uncertainty here, don't forget I'm about as competent on most of this as a reasonably clever hamster.
« Reply #7 on: August 26, 2020, 05:44:29 AM »
I've also contacted Autodesk about this, if I end up with an answer from them I'll make sure to share the findings here.
Marc
« Reply #8 on: August 26, 2020, 07:59:37 AM »
you can at first step  ,change this by notepad and test
but i also suggest you use same tool ,same program(more or less) to be sure the nc file its the problem
« Reply #9 on: August 26, 2020, 08:25:48 AM »
I switched from Fusion360 to Sheetcam due to this issue. Since sheetcam is not creating this problem I included the file to provide a possible means of diagnosis from something that does work on the same equipment vs something that doesn't.
