Hello Guest it is November 22, 2026, 11:05:31 AM
Author Topic: Mach 3 auto zero script  (Read 13372 times)
Offline jon b
  •  22 22
« on: August 24, 2020, 04:45:47 AM »
Hi guys i am looking for a current version of the script to copy into mach 3 for auto zero probe metric version .can anyone point me in the correct direction.
regards Jon UK
measure twice cut once !! so why is my bin always full
  •  9,378 9,378
Re: Mach 3 auto zero script
« Reply #1 on: August 24, 2020, 05:01:52 AM »
There are many to choose from but the one I use is at the bottom of this page;  http://www.tweakie.byethost10.com/17.htm?i=1
Offline jon b
  •  22 22
« Reply #2 on: August 24, 2020, 09:33:25 AM »
Hay
thank you Twekie just the job  ;D
Offline jon b
  •  22 22
« Reply #3 on: September 02, 2020, 03:42:20 AM »
Hi Twekie
 ive hit a wall trying to set up script for the z touch probe just cant get my head around it . could you possible fill in the blanks on your script ? . touch plate is 40.37mm
 maz z travel is 100mm
i think standoff distance above probe has to be greater than 40.37 mm ? beyond me im afraid .
 any information gladly received
  •  9,378 9,378
« Reply #4 on: September 02, 2020, 03:51:52 AM »
Try this one...
Online ZASto
  •  434 434
« Reply #5 on: September 02, 2020, 05:05:29 AM »
Why should you have hard coded plate thickness?
For portability between different machines/installations, it would be much easier to use value entered in DRO.
For 1024 screen set it is OEMDro 1001 or 1002, and for Big-Tex screen set it is OEMDro 1151
Attached script is from Big-Tex screen set
My personality is who I am.
