Hello
Guest
it is
November 26, 2026, 06:31:07 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach4 General Discussion
Mach4 Command to disable Z Axis
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mach4 Command to disable Z Axis (Read 5473 times)
saxmax
1
on:
August 16, 2020, 11:40:10 AM »
hi everybody,
I a newby and i want just know if it's possible to create a commande or a button to disable z Axis?
I want move Z axis with handle to adjust Z0 with a screw.
Thanks a lot !!!
Logged
joeaverage
7,663
Re: Mach4 Command to disable Z Axis
Reply #1 on:
August 17, 2020, 03:12:40 AM »
the simplest way would be to have the Z axis stepper enable separate from X and Y axis enables and then you could
alternately enable or disable the Z axis stepper drive at will.
Logged
Print
Pages:
1
Go Up
« previous
next »
