Mach Discussion => Mach4 General Discussion => Topic started by: saxmax on August 16, 2020, 12:40:10 PM
hi everybody,
I a newby and i want just know if it's possible to create a commande or a button to disable z Axis?
I want move Z axis with handle to adjust Z0 with a screw.
Thanks a lot !!!
the simplest way would be to have the Z axis stepper enable separate from X and Y axis enables and then you could
alternately enable or disable the Z axis stepper drive at will.
