Hello Guest it is October 24, 2026, 07:08:38 PM
Author Topic: Setup - x axis jogging problem  (Read 10126 times)
« on: August 11, 2020, 07:20:58 AM »
when i use my right arrow key, the spindle moves left and vice versa with left arrow key. Also, as spindle moves right, the coordinates decrease (become more negative). is this a software or hardware problem? help!!
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Setup - x axis jogging problem
« Reply #1 on: August 11, 2020, 07:52:01 PM »
search on here for the right hand rule, stand facing machine with your right hand turned up and your thumb facing right, first finger facing forward and second finger facing up,  these are the plus directions of the spindle when moving.  Forget about the table moving its always the spindle that moves.
  •  9,374 9,374
« Reply #2 on: August 11, 2020, 11:54:12 PM »
In Config, / Ports & Pins / Motor Outputs  change the 'Dir Low Active' state for your X axis.
