Hello Guest it is November 10, 2026, 02:44:52 AM
Author Topic: edge finding/2.5D probing  (Read 340881 times)
Re: edge finding/2.5D probing
« Reply #160 on: June 15, 2011, 03:56:26 AM »
Any new stuff going on with edge probing?
« Reply #161 on: June 15, 2011, 10:22:58 AM »
If you are a probe user, you may be interested in the abilities built into the MachStdMill software:
http://www.calypsoventures.com/machstdmill/videos.html
www.CalypsoVentures.com
« Reply #162 on: June 15, 2011, 05:45:30 PM »
I looked at that, thank you.
I downloaded Stirling's program, but i can't get it working. Probe comes down, moves forward to contact, retracts, moves forward to contact and then stops. I have adjusted speeds and acceleration up and down. I'm not sure what to try next. I think I'm almost there. Help.
EDIT: By Stirling. As I explained in our PM correspondence it clearly states in your controller manual that Ajax handles G31/probing differently from the standard Mach3 way and that's why my routines don't work FOR YOU. It's unlikely that ANY Mach probing routines will work with the Ajax controller UNLESS they're specifically written for it.
Ian
« Last Edit: September 04, 2011, 02:15:22 AM by stirling »
Offline dude1
  •  1,253 1,253
« Reply #163 on: June 11, 2012, 07:38:01 PM »
« Reply #164 on: June 12, 2012, 02:21:22 AM »
I have been using the polar array probing program. It runs fine.
« Reply #165 on: November 14, 2012, 02:42:32 PM »
Marv
Have you downloaded the latest version and the readme? http://www.razordance.co.uk/probe25D.htm
If you can tell me your specific problem i.e. how far have you got. I'll try to help.
Ian
Stirling, where can I get a copy of your probing routine? I'm doing some edge probing experimentation and your Mach probing routine will give me a good starting point.  I understand I will be totally responsible for any issues I may have using it.
Thanks. Jeff
Extensivly Re-worked/Re-designed/Modified Servo K2CNC KG-3925 and the Mini Laser Engraver
« Reply #166 on: November 14, 2012, 03:09:42 PM »
Stirling Mentioned a while back that he had ideas for a much better 3d process. Hopefully he will bring out the new DELUXE model soon.
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #167 on: November 16, 2012, 09:48:48 AM »
Hi Jeff - I've sent you a PM.
Hi Terry - I'm currently working on the DELUXE model which will have some NICE new features - preview coming soon! (I'm also the most part through coding a brand new all singing all dancing screen editor).
Ian
« Reply #168 on: November 29, 2012, 04:16:35 PM »
Ian,
I'm very impressed how good your probing routines work in Mach3. Can't wait for your Deluxe version to come out. Thanks again.
Dave,
I really like your MachStdMill Professional Edition with the probing operations also. Still running the Trial License, but will register it soon.
Jeff
https://www.youtube.com/watch?v=9skopcbhurU
Offline stirling
  •  2,188 2,188
  • UK
« Reply #169 on: December 05, 2012, 05:11:04 AM »
Jeff - thanks for the comments and the video - glad it does what you want.
Ian
