Hello Guest it is November 28, 2026, 12:29:37 AM
Author Topic: Google Assistant/Alexa/Siri Broadcasting  (Read 47366 times)
« on: August 07, 2020, 06:39:27 PM »
WTB a Mach4 plugin that will broadcast to either Google Assistant or Siri that the machine has finished or a tool change is needed to continue. If you have an ai assistant around the work shop or in another room, when Mach4 stops it should broadcast a message to google assistant around the house or notify Siri that the program has ended or you need to change bit.
Please and Thank You!
