Hello Guest it is September 09, 2026, 11:49:17 AM
Author Topic: Switching license from Mach4 to Mach3  (Read 24356 times)
« on: July 14, 2020, 10:12:27 PM »
Can anyone tell me if it is possible to switch a Mach4 licence to Mach3?  I have had endless hassles trying to get my controller (horrible CSMIO/P-M with no support from the manufacturers) working properly with Mach4.  I did have it all running OK until I upgraded the firmware on the controller - now I cant get the touch sensor to work (although it is wired correctly & led comes on when touched) - and I can no longer control my spindle speed from the GUI.
At this point I am just so frustrated I want to go back to Mach3 & may go back to the cheap Chinese controller I had previously ...
Offline thosj
  •  542 542
Re: Switching license from Mach4 to Mach3
« Reply #1 on: July 15, 2020, 07:01:41 AM »
You must have had a Mach3 license previously, correct? So just use that one. The licenses, Mach3 and Mach4, use different mechanisms, so I doubt you can switch. Mach3 just uses a license file and I don't remember how you got a new file if you deleted your old Mach3 install and hence deleted the license file.
Tom
« Reply #2 on: July 15, 2020, 04:14:48 PM »
No, unfortunately not - I imported this machine from China & it came with a pirated version of Mach3.  I upgraded the machine to the CSMIO/P-M controller (piece of crap - should have bought an American product!) and Mach4 - and I did buy a Mach4 Hobby license, but the plug-in for Mach4 is so buggy it is unusable.  So now I would like to go back to Mach3 just to see if this crappy controller can actually be used at all.
Anyone want to trade for an ESS controller?
« Reply #3 on: July 15, 2020, 04:45:18 PM »
i use pokeys +mach4 on chines machine, on complex chines cnc(with 2 machines run parallel)without problem
https://youtu.be/eORzkPKqkXM
« Reply #4 on: July 15, 2020, 04:47:54 PM »
 chines use chines card for mach 3 and its real disaster unstable ,i suggest you not even think about stay with chines mach 3 cards
Offline thosj
  •  542 542
« Reply #5 on: July 15, 2020, 05:38:44 PM »
So it's one of two choices, buy an ESS and keep using Mach4 (RECOMMENDED) or buy a Mach3 license.
I'd sell the CSMIO and buy the ESS for sure!! Mach3 is too old to start with now, and Mach4 is SO much better.
Tom
Tom
« Reply #6 on: July 15, 2020, 11:21:01 PM »
I agree with Tom, an ESS and Mach4 is a good combination. Bear in mind you need a breakout board or boards with an ESS.
The CSMIO works very well with Mach3 so its not an unreasonable proposition to buy a Mach3 license at $175. However the cost
of an ESS at $180 makes it about a wash. You will get good money for the CSMIO amongst Mach3 users, easily enough to get an ESS
and probably an MB3 breakout board.
« Reply #7 on: July 16, 2020, 01:37:31 AM »
I really appreciate all the input.  I spent most of today getting the CSMIO going with Mach3 (Demo version) and I think it's now running pretty sweet.  I really would prefer running Mach4, but I don't relish the thought of rewiring the machine again - I still have nightmares from the first time :-(
« Reply #8 on: July 16, 2020, 03:01:20 AM »
its not so much that there is anything wrong with Mach3 just that Mach4 is so much better:
https://www.machsupport.com/forum/index.php?topic=42891.0
« Reply #9 on: July 16, 2020, 05:15:33 AM »
when i decided to start use mach(before i use Tpa italy) i search for hardware supplier in europe
i had 2 main options Pokeys or CSIMO
i check both of them ,i wanted to choose csimo but then when i search on plugins always its was written  mach3
when i asked ,i need mach4 they said ohhh its ok we have both
so seem its not real match mach4
