Hello Guest it is November 13, 2026, 10:37:24 AM
Author Topic: Force feedrate / Max speed while program is running  (Read 7279 times)
« on: July 03, 2020, 10:57:12 AM »
Hello all,
For cycle time and machine lifetime reasons I want to use the Tempest motion planner which was made several years ago for mach3. The only problem I have with it is that the feedrate overide has been disactivated and I really want / need it.
I have been trying to create a macropump which would change the max speed of the axis depending on a potmeter, macro works but the changes do not happen while the program is running.
I also tried using OEMDro and #99********* to specify the feedrate through macropump and potmeter, but again this does not work after program has been started.
Does any of you have a brillant idea how to do that?
Cordially
Cemoa9
Re: Force feedrate / Max speed while program is running
« Reply #1 on: July 04, 2020, 08:58:43 AM »
Hello,
So one thing which works but is not perfect is to have a lot of M1 in the program, when activated and machine stops it updates the max motor speed of all axis following the macro.
Still if somebody gets a better solution...
Cordially
Cemoa9
