Hello Guest it is November 21, 2026, 03:16:46 PM
Author Topic: 7766: ERROR: Motor 0 Set Still without in position 339695 339694  (Read 13609 times)
I'm getting this error from the plugin every time I change direction:
[20:27:08.424] Waiting for controller to consume buffered motion: Mtr: 0 SeqID: Ctrl 943999 Mach 944007
[20:27:08.434] *><><* Motor 0 is almost in position 339695.00 339694.98
[20:27:08.434] *><><* Motor 1 is almost in position 332600.00 332600.00
[20:27:08.435] *><><* Motor 2 is almost in position -330478.00 -330478.02
[20:27:08.464] ########### ERROR: Motor 0 Set Still without in position 339695 339694
[20:27:08.464] MotionSetStill for motor 0
[20:27:08.465] ########### ERROR: Motor 1 Set Still without in position 332600 332600
[20:27:08.465] MotionSetStill for motor 1
[20:27:08.465] ########### ERROR: Motor 2 Set Still without in position -330478 -330478
[20:27:08.466] MotionSetStill for motor 2
[20:27:08.466] Motors are now set still:
  • Pos=339695, Actual=339695.00, StepGen 339695, Plugin 339694
  • [1] Pos=332600, Actual=332600.00, StepGen 332600, Plugin 332600
            [2] Pos=-330478, Actual=-330478.00, StepGen -330478, Plugin -330478
    Anything to worry about?
    Mach4 4.2.0.4300
    Mach4300-Integra-4.18_Plugin-2.03.33
    7766 FPGA: A2B2
    /Olovsson
Re: 7766: ERROR: Motor 0 Set Still without in position 339695 339694
« Reply #1 on: June 29, 2020, 03:44:02 PM »
Nothing to worry about. The machine is probably running very slowly. Both position numbers are matching and the message " Motors are now set still:" means it is working as intended.
