Hello Guest it is November 13, 2026, 01:14:39 PM
Author Topic: Locking a Mach3 setup  (Read 22272 times)
Offline Davek0974
  •  2,606 2,606
« on: June 25, 2020, 12:51:31 AM »
Is there a way to lock the general config of a Mach3 setup?
I run Plasma with it and find that the "Use Watchdogs" tick box keeps turning itself on in general config.
I turn it off, press "save settings" on menu and at a random time it turns back on :(
The machine is not so happy when its on and will fault out for seemingly no reason at random times, its far better with it off.
Offline Davek0974
  •  2,606 2,606
Re: Locking a Mach3 setup
« Reply #1 on: June 26, 2020, 02:10:08 PM »
Anyone??
Offline TPS
  •  2,627 2,627
« Reply #2 on: June 26, 2020, 02:21:36 PM »
hello Dave,
witch Version?
Offline Davek0974
  •  2,606 2,606
« Reply #3 on: June 26, 2020, 02:24:54 PM »
062
Offline TPS
  •  2,627 2,627
« Reply #4 on: June 27, 2020, 02:06:11 AM »
sorry no real idea,
i run 022 on all my machines, and never had any issue
Offline Davek0974
  •  2,606 2,606
« Reply #5 on: June 27, 2020, 02:09:30 AM »
Ok, it is an odd one, i cant see why it keeps turning on, have to keep checking its off.
Could be related to the C&CNC THC theme i guess, not much i can do about that.
I don't suppose there is a file that could be made read-only on the disk or would that cause more issues?
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #6 on: June 27, 2020, 08:20:48 PM »
The watchdog setting is stored in your profiles xml file so locking it would be a problem.
I have no memory of a VB call to turn the watchdog on or off so it must be a low level command in a plug in that is doing it.
Or it could be memory corruption.
All very strange though if its random.
Offline Davek0974
  •  2,606 2,606
« Reply #7 on: June 28, 2020, 12:44:54 AM »
OK, thanks all,
I guess i'll have to live with it :)
I might contact C&CNC if they are still going to see if there is a known issue with this older version of their THC.
  •  2,785 2,785
« Reply #8 on: June 28, 2020, 12:52:28 PM »
I have done a bit of digging on this one, there is a feature/bug/action where if you cancel/stop/interrupt a g-code file loading it turns the watchdog on.
Could this be the cause?
Offline Davek0974
  •  2,606 2,606
« Reply #9 on: June 28, 2020, 01:02:00 PM »
Interesting, i was not even aware that once the load file button was acted on it could be stopped?
In my case i don't see how it could be that unless some of the load code - this is custom C&CNC THC stuff which reads voltage and height settings [S_Codes] from the file is doing it??
I will have to have a play when i get a gap and see if a sequence or event actually triggers it
