Hello Guest it is November 13, 2026, 09:42:54 AM
Author Topic: Locking a Mach3 setup  (Read 22254 times)
Offline TPS
  •  2,627 2,627
Re: Locking a Mach3 setup
« Reply #10 on: June 28, 2020, 01:04:59 PM »
if you Google for sysinternals filemon, it might be a help to find who is changing the file.
Offline Davek0974
  •  2,606 2,606
« Reply #11 on: June 28, 2020, 01:10:50 PM »
Offline Davek0974
  •  2,606 2,606
« Reply #12 on: June 30, 2020, 06:27:04 AM »
I have done a bit of digging on this one, there is a feature/bug/action where if you cancel/stop/interrupt a g-code file loading it turns the watchdog on.
Could this be the cause?
You are correct
I tested this morning, and if the file-load is called and then cancelled it flips the watchdog thingy to on!
I have no idea why or how that could have crept into the source code but of course its there forever ;)
At least i know that i need to check after each file load now.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #13 on: July 02, 2020, 06:37:22 AM »
Another undocumented feature discovered  :D
Offline Davek0974
  •  2,606 2,606
« Reply #14 on: July 02, 2020, 06:40:19 AM »
Yep, its the file-load "Cancel"button triggers it.
If you invoke file-load and press "Cancel" it flips the watchdogs on.
If you invoke file-load and press "Ok" without selecting a file it cancels the load request and does NOT flip the watchdog on.
