Hello Guest it is November 13, 2026, 01:02:38 PM
Author Topic: There are issues with dual core2 dual processors,need close 1 cpu  (Read 13350 times)
It is very strange, when mach3 work  none of my motors would work properly. They would only turn slowly and vibrate profusely,lose steps.
1 i set Task Manager-Processes-mach3.exe-affinity - cpu0 or cpu1 ,   it not useful,motors still slowly and vibrate profusely
2 when mach3 working ,i run any other software at the same time , the Motors  run smoothly immediately。
3 i set win+r-msconifg-boot.ini-advanced-/NUMPROC(N)=1,reboot laptop, the Motors  run smoothly immediately
please help , i dont want use only 1 cpu  ,coz it is core 2 dual ;D
regard!
« Last Edit: June 24, 2020, 11:36:17 PM by lagogo »
  •  9,377 9,377
Re: There are issues with dual core2 dual processors,need close 1 cpu
« Reply #1 on: June 25, 2020, 12:11:56 AM »
Which motion controller are you using ?
« Reply #2 on: June 25, 2020, 01:36:43 AM »
i use LPT port motion controller :)
cpu is Intel Core 2 Duo processor, P8700 - 2.53GHz, 1067MHz FSB, 3MB L2 cache
« Last Edit: June 25, 2020, 01:43:12 AM by lagogo »
  •  9,377 9,377
« Reply #3 on: June 25, 2020, 01:49:46 AM »
Unfortunately Mach3 will not operate correctly using a Laptop with a Parallel Port - you need to be using a PC with Parallel Port or a Laptop with motion controller.
  •  9,377 9,377
« Reply #4 on: June 25, 2020, 01:51:55 AM »
The Mach3 requirements are here;  https://www.machsupport.com/software/mach3/
« Reply #5 on: June 25, 2020, 03:02:30 AM »
so i need change an usb motion controller ?i thought parallel port is better than usb  :(
  •  9,377 9,377
« Reply #6 on: June 25, 2020, 03:23:21 AM »
If you decide on a motion controller then choose one from EU or USA manufacture - avoid anything from China.
If you choose anything from a business that is listed in this thread then forum support may be limited; https://www.machsupport.com/forum/index.php?topic=24331.0
There are many to choose from but the Warp9 ESS is good.
« Last Edit: June 25, 2020, 06:14:53 AM by Tweakie.CNC »
« Reply #7 on: June 25, 2020, 12:45:47 PM »
  thank you  .
this is the video of the problem  :) https://www.youtube.com/watch?v=PWwS_NvnwKg
« Reply #8 on: June 30, 2020, 01:15:56 PM »
Try following the instructions in this link
http://support.machsupport.com/en/kb/articles/mach3-xp-optimization-txt-steps
especially changing from ACPI to standard PC
Marsha
Driving my CNC with old Dell D600 1.6mhz laptop
