Hello Guest it is November 13, 2026, 09:38:01 AM
Author Topic: mach 3 turn tool table  (Read 6847 times)
« on: June 16, 2020, 02:13:51 AM »
sorry if im asking a stupid question ...
if i have the tool table populated  with t1 as a master tool.
say i profile some stock with t1 and its 40mm which is correct
i then use tool 3 to do another operation and make it 35.    when measured its 34
so can i without moving the x   just go into tool table make sure t3 is in the window  change part zero to 34  then hit touch x
so its a bit like populating the table by making and measuring test cuts with each tool rather than touching off
thanks
