Mach Discussion => General Mach Discussion => Topic started by: chessie on June 16, 2020, 03:13:51 AM
sorry if im asking a stupid question ...
if i have the tool table populated with t1 as a master tool.
say i profile some stock with t1 and its 40mm which is correct
i then use tool 3 to do another operation and make it 35. when measured its 34
so can i without moving the x just go into tool table make sure t3 is in the window change part zero to 34 then hit touch x
so its a bit like populating the table by making and measuring test cuts with each tool rather than touching off
thanks
