Hello Guest it is November 13, 2026, 11:06:04 PM
Author Topic: Using different screen sets  (Read 9606 times)
Offline bowber
  •  216 216
  • Kirkby Stephen,Cumbria, UK
« on: September 26, 2007, 08:18:43 AM »
Hi All
Got my last problem sorted with limit switches etc, many thanks to all that helped.
I've what I hope is a simple question.
How do you use the different screen sets that people have created? is it just a simple selection in Mach3 (presume the screen set has to be in the Mach folder) or is there more involved?
Also can you change back to the default set?
I'm just wanting to use a simple 4 axis set without spindle control and just the main buttons on screen, Is there a screen set like this available for Mach3 Mill?
Steve
Re: Using different screen sets
« Reply #1 on: September 26, 2007, 08:56:25 AM »
Hey Steve,
    Yes, it is that simple. At the top of Mach, you should see a tab that says View. Click o that, load screens, if it doesn't come up to the default C/Mach 3 folder, browse to it and select the screen you want to use. It's just as easy to go back to the default set.
You might want to search around for other screen sets.
Offline bowber
  •  216 216
« Reply #2 on: September 26, 2007, 09:30:20 AM »
Hi
Thanks for the reply.
I'll search through the screen sets and try a few.
Steve
