Hello Guest it is September 16, 2026, 04:48:26 PM
Author Topic: Mach3 Not Detecting LPT Port using Windows 10  (Read 8976 times)
« on: May 19, 2020, 09:44:57 PM »
Hello,
I'm spinning in circles trying to get Mach3 to run under Windows 10.
Here is some history.
I bought a old Optiplex 745 PC for it's parallel port. It was running Windows XP SP-3 and I had the LPT port in the BIOS set to ECP and DMA1. Mach 3 worked fine. The parallel port was communicating with my BOB.
It turned out the G-Code Ripper would not run under Windows XP
So I installed Windows 10. G-Code Ripper now runs, but Mach3 is not detect the LPT port. The BIOS settings have not been changed. When I install Mach3, when it tries to install the parallel driver; it says "no driver found.
Inside the device manager Windows says the driver is working properly.
I have tried run the DriverTest inside the Mach3 folder, but it doesn't work.
Has anyone here experienced this problem or know how to solve this problem?
Re: Mach3 Not Detecting LPT Port using Windows 10
« Reply #1 on: May 19, 2020, 10:09:43 PM »
Machs parallel port WILL NOT RUN under Windows 10, it requires 32 bit Windows 7 or earlier.
« Reply #2 on: May 23, 2020, 08:18:07 AM »
Windows 10 requires a USB to parallel motion controller such as the Automation Technologies UC100 or UC300.  A "standard" USP to parallel "adapter" won't work.  There are other options but this is the one I used so it is the one I remember.
Richard
