Mach Discussion => General Mach Discussion => Topic started by: vcholman on May 19, 2020, 10:44:57 PM
Title: Mach3 Not Detecting LPT Port using Windows 10
Post by: vcholman on May 19, 2020, 10:44:57 PM
Hello,
I'm spinning in circles trying to get Mach3 to run under Windows 10.
Here is some history.
I bought a old Optiplex 745 PC for it's parallel port. It was running Windows XP SP-3 and I had the LPT port in the BIOS set to ECP and DMA1. Mach 3 worked fine. The parallel port was communicating with my BOB.
It turned out the G-Code Ripper would not run under Windows XP
So I installed Windows 10. G-Code Ripper now runs, but Mach3 is not detect the LPT port. The BIOS settings have not been changed. When I install Mach3, when it tries to install the parallel driver; it says "no driver found.
Inside the device manager Windows says the driver is working properly.
I have tried run the DriverTest inside the Mach3 folder, but it doesn't work.
Has anyone here experienced this problem or know how to solve this problem?
Title: Re: Mach3 Not Detecting LPT Port using Windows 10
Post by: joeaverage on May 19, 2020, 11:09:43 PM
Machs parallel port WILL NOT RUN under Windows 10, it requires 32 bit Windows 7 or earlier.
Post by: nowdkyle on May 23, 2020, 09:18:07 AM
Windows 10 requires a USB to parallel motion controller such as the Automation Technologies UC100 or UC300.  A "standard" USP to parallel "adapter" won't work.  There are other options but this is the one I used so it is the one I remember.
Richard
