Hello Guest it is October 20, 2026, 03:04:22 PM
Author Topic: Pulsing to fast, ACPI to standard pc  (Read 8486 times)
« on: May 15, 2020, 04:55:24 PM »
Steppers are stopping, and missing steps. tried changing Vref on stepper controller, changing speed and velocity in motor tune with no luck. tried changing the ACPI to standard, but I dont see a standard driver when I look for it. I can only get 40IPM out of the steppers and need at least twice that.
Running probotix pbx-rf breakout, sidestepper controllers at 1.5A, 280oz in steppers, 1/4 20 screws.
  •  9,374 9,374
Re: Pulsing to fast, ACPI to standard pc
« Reply #1 on: May 16, 2020, 09:07:03 AM »
Are you running your steppers at the maximum voltage the drivers will allow ?
« Reply #2 on: May 16, 2020, 02:29:15 PM »
No. have them set at 1A, stepper controllers can go to 2.5. I have tried all the way up to 2.5 and down to .5. This machine doesnt have any force put on the steppers while running. Just moves the x and y.
  •  9,374 9,374
« Reply #3 on: May 17, 2020, 12:06:24 AM »
That is Current - What Voltage are you running your steppers at ?
Are you running them at the maximum Voltage that your drivers allow ?
(basically Current determines Torque and Voltage determines Speed).
