Hello Guest it is November 03, 2026, 08:14:38 AM
Author Topic: How can i cut 2mm Styrene sheet correctly and at what speed?  (Read 11559 times)
Hi
   I have a 2030 machine ( A cheap one from China) and I am having difficulty with the speeds and feeds for cutting 0.5mm to 2mm Styrene Sheet. Whatever speed and feed rate I use the styrene is melting and clogging the cutter.  Is there a list somewhere to give me speeds and feeds for various materials.
The only other material I use at the moment is thin plywood 0.5mm to 3mm and there I have no problems at all.
Many thanks for any advice
Regards
Roy
