Hello Guest it is September 28, 2026, 05:56:38 PM
Author Topic: I need help with e-stop  (Read 29663 times)
Offline ZASto
  •  434 434
Re: I need help with e-stop
« Reply #20 on: May 23, 2020, 07:39:43 AM »
Glad you figured out :)
Make no mistake between my personality and my attitude.
My personality is who I am.
My attitude depends on who you are.
Offline Boss6
  •  13 13
« Reply #21 on: May 26, 2020, 07:44:03 AM »
Machining with the machine is much safer now. Thanks all for your input. I hope my post will help someone that may run across the same problem I had.
Offline MN300
  •  306 306
« Reply #22 on: May 26, 2020, 07:54:34 AM »
Is wire #127 the correct number? It appears to be in the former limit switch circuit, not the E-Stop.
Offline Boss6
  •  13 13
« Reply #23 on: May 29, 2020, 06:22:09 AM »
Connection to wire 127 is doing the job. I found it by using a VOM and checked it with e-stop engaged and not engaged. Now if I use the machines e-stop it also triggers the mach 3 e-stop. I still have to reset both the the machines e-stop and the mach 3 e-stop to restart but it is much safer than the way it was before.
Offline ZASto
  •  434 434
« Reply #24 on: May 29, 2020, 06:32:38 AM »
In any case, when you disengage EStop, you should reset Mach and rehome the machine.
Safe enough?
