Hello Guest it is November 22, 2026, 02:24:46 PM
Author Topic: EZ Router with Air Drill  (Read 10346 times)
« on: September 24, 2007, 01:57:43 PM »
We have just purchased an EZ Router with an Air Drill piggy backed on the z-Axis. When the Air is turned on the drill comes down and starts spinning. Any ideas how that could be turned on and off with G code. In Mach 3 I can hit a button that says "Air on" and "Air off", but obviously I need to turn it on and off with a program.
Re: EZ Router with Air Drill
« Reply #1 on: September 24, 2007, 03:22:01 PM »
You could make your self a macro to do it then add the macro to your button. When you need it to perform the action in Your Gcode, just call the macro. M2010 for example.
« Reply #2 on: September 24, 2007, 07:03:01 PM »
You could have your M3 turn it on, and set up your output relay in your config and yoru ports and pins
the M5 can then turn it off...........
scott
« Reply #3 on: September 25, 2007, 02:17:24 PM »
I actually found out from EZ Router that the Air Drill can be turned on with M12 and off with M13. Thanks all for the help.
