Hello Guest it is November 25, 2026, 04:04:14 AM
Author Topic: Win 7 32bit, driver test OK, steppers have power but do not move  (Read 10429 times)
Hi I am new and just starting to try work this out but have hit a wall
I am 32-bit win 7 on a laptop
I have set the pins x 23 y 45 z 67
Steppers have power
but no movement -
Driver test good
the only difference is the laptop does not have a traditional printer plug so I bought an adapter USB to lpt1
HELP, please
I am using a 6600 driver card I know I bought it some years ago as a project that lockdown has given me the opportunity to build and I would just like to be able to have a win do I have the jumpers set wrong?? it is how it come so I did not mess with it
cheers
« Last Edit: May 09, 2020, 06:06:00 AM by Graham Waterworth »
  •  9,378 9,378
Re: Win 7 32bit, driver test OK, steppers have power but do not move
« Reply #1 on: May 09, 2020, 12:19:45 AM »
The adapter USB to LPT1 will not work - you need an external motion controller if you plan on using a laptop.
« Reply #2 on: May 10, 2020, 06:41:26 PM »
Yes you are right I dumped everything went to the corner of the shed and found an old tower and hard drive after many hrs got win XP up and it worked I am now functional phase one complete - thanks
  •  9,378 9,378
« Reply #3 on: May 11, 2020, 12:15:56 AM »
Excellent  ;)
