Hello Guest it is November 27, 2026, 09:37:12 PM
Author Topic: Adding more inputs to Mach3 to run Contec card  (Read 524335 times)
« on: May 02, 2020, 09:59:51 PM »
Hi all, I have A Cincinnati Milacron machine running two PIO16/16t cards and a Galil motion controller. The software is Camsoft and I am changing it to run on Mach3. Mach3 is loaded and the Galil plugin and Contec plugin and working good. The Contec cards mainly run the 24 tool ATC and I would like to make a macro in Mach3 to run it like Camsoft does. The problem is I do not have enough user input/output controls in the Ports & Pins menu in Mach3. There are 15 user inputs and 20 user outputs from memory. Can i add more somehow so i can use all 32 inputs and 32 outputs on my Contec Cards.
Cheers,
Mark
